Electronic Document Distribution
At A Glance:
•         Control document distribution expenses
•         Capture and distribute documents electronically
•         Increase productivity
•         Maximize workflow
With the explosion of the Internet and corporate e-mail usage, companies have seen a dramatic increase in the amount of paper they're using. Businesses worldwide are challenged with the amount of paper that's circulated throughout the office and then hand routed, mailed, stored, or eventually lost. The expenses associated with manually distributed paper, both direct and indirect, can be enormous. Canon Business Solutions helps organizations control these expenses and enhance productivity with solutions that leverage existing IT investments to capture and distribute documents electronically. Whether you’re sending one document or many you can be sure that the process will run smoothly and they can work with your documents without delay. So if you want to work more efficiently with a cost effective way of sharing your documents, now you can.
  • Learn MoreAuthorized Send
    Authorized Send
    Authorized Send provides you with a secure, easy-to-use interface for document delivery from MEAP-compatible imageRUNNER and imagePRESS solutions.
  • Learn MoreeCopy
    eCopy
    eCopy helps your organization by converting paper into secure digital documents, and connecting you with the applications and digital workflows that run your business.
  • Learn MorePaperToOffice
    PaperToOffice
    PaperToOffice Pro is a simple-to-use software application that converts paper documents to electronic Microsoft Office formats, saving you from having to recreate the documents manually.
  • Learn MoreUniversal Send
    Universal Send
    Send any kind of document (paper or electronic) via a Local Area Network, the Internet, or a Public Switched Telephone Network (PSTN) to multiple destinations—all in one simple, time-saving operation.
  • Learn MoreCaptaris Fax Integration for MEAP
    This embedded application allows for bi-directional communication between the imageRUNNER device and RightFax Server.
  • Learn MoreScan-To-Database
    Scan-To-Database
    Scan-to-Database is a customizable MEAP application that allows you to scan documents from the imageRUNNER device directly into your company's database and/or content management system.
