Onyx ProductionHouse
At A Glance:
  Print with aqueous, solvent, or UV inks
  Profile your own media
  Color proof across devices
  Run four active printers and two simultaneous RIPS, including grand-format and white ink capabilities
Onyx ProductionHouse is one easy workflow solution that produces great color on all of your devices. All of your jobs follow the same easy workflow and all of your printer operators use this same easy workflow regardless of output device.
