Document Mastering
Document Mastering
At A Glance:
•         Deliver high-quality documents quickly and easily
•         Optimize output for common printers
•         Easily manipulate documents
•         Combine multiple documents regardless of format
Document Mastering is at the center of both casual and production-oriented POD environments. From simple scanning to complex document impositions, the ability to efficiently perform make-ready tasks and manage job workflow is not an option in today's competitive POD marketplace. Print service providers must be ready for anything that customers bring you, in whatever form they provide it - on disk, CD, via network, hard copy, anything. Canon Business Solutions helps print service providers and in-house CRDs by delivering a comprehensive set of Document Mastering solutions designed to meet the needs of even the most demanding customers.
  • Learn MoreEFI MicroPRESS
    EFI MicroPRESS
    MicroPress is a fast, high-performance raster-based digital document production system for mid-to-high-volume print-on-demand environments that produces complex, short-run, color and black and white documents.
  • Learn MoreimageWARE Publishing Manager
    Publishing Manager is an easy-to-use desktop software application that simplifies document creation involving content that is stored in both hardcopy and electronic formats.
  • Learn MoreImageSmart Document Mastering Suite
    Enhance the production capabilities of the imageRUNNER 110/110M/Pro 150+ Networked Production Systems. Based upon industry-standard Adobe Acrobat software, and utilizing PDF-based workflow, ImageSmart Document Mastering software is a powerful, “make-ready” workflow tool for document assembly, viewing, editing, and proofing.
  • Learn MoreRSA RDO Print
    RSA RDO Print
    With RDOPrint, you can leverage your investment in documents created by Xerox DigiPath. RDOPrint converts the proprietary Xerox RDO (Raster Document Objects) files to PostScript so they can be printed on any PostScript printer or converted to PDF for convenient viewing, sharing, and archival.
  • Learn MoreALTO Image Arranger
    ALTO Image Arranger
    Capture paper documents or integrate electronic information for output to the most sophisticated printers with ALTO Image Arranger.
  • Learn MoreimageWARE Prepress Manager
    imageWARE Prepress Manager is a comprehensive Document Make Ready and Production Workflow tool designed to simplify the document publishing process.
  • Learn MoreSmartBoard Workflow Suite
    Kodak SmartBoard Document Mastering Software enables fast and easy job setup including creating job tickets, labeling and inserting tabs, and assigning page level features.
