At A Glance:
| • | Eliminates the need for costly third party connectivity products | |
| • | A one-time purchase as opposed to a leased connectivity solution | |
| • | Software solution for print spooling eliminates need for additional hardware | |
| • | Allows for improved use of bandwidth for higher speeds at lower costs through its built-in compression capability |
RSA Mainframe Downloader is a software solution that delivers TCP/IP print spooling capability for mainframes—saving thousands of dollars over hardware solutions. AES Encryption and compression ensure optimal use of bandwidth while maintaining security, point-to-point. Mainframe Downloader pays for itself almost immediately, and frees enterprises from yearly leases of expensive hardware.
Advantages of Mainframe Downloader:
| • | Meets the encryption, security, and auditing requirements demanded by IT departments. | |
| • | Provides LCDS/Metacode/XES data transmission over TCP/IP. | |
| • | Maintains data integrity—carriage control, record structure, and binary data are transmitted intact. | |
| • | Communicates all JES parameters to receiving systems. | |
| • | Provides both mainframe or destination Exit points. | |
| • | Allows you to add banner pages or DJDEs to mimic JES Exit processing. |
