At A Glance:
• Complete accountability of print/copy across the network
• Ensures 100% print/copy availability and secure document release
• Brings control and efficiency to the print infrastructure
• Modular and configurable to fit your business' or department's needs
uniFLOW allows you to accurately measure usage and cost by user, workgroup or department. Through the detailed reporting capability of the software, you can make the most effective use of your output resources by minimizing costs and strategically placing devices in areas where they are most needed.
uniFLOW is more than just a print analysis and reporting solution—it's a way of gaining total control over your print environment. In the office, its re-routing capability allows you to redirect print jobs to the most cost-efficient device based on size and quality (B&W, Color). It can also divert output to alternative devices in the event of a problem, so that staff productivity is not affected.
Whatever the size of your company, you can use the uniFLOW solution to gain effective control and management of your entire printer fleet. This comprehensive, Web-based software system is both modular and configurable, allowing the implementation of a solution that’s aligned to your specific business requirements.
For more information about uniFLOW, call 1-800-815-4000 or email BusDev@solutions.canon.com.
