At A Glance:
• Track copy, scan, send & fax jobs
• Output restriction (Usage Limits)
• Analyze department/device workload
• Export reports
Accounting Manager is ideal for any organization that needs to control the costs of printing, copying, faxing, and scanning.
Accounting Manager is a Web-based application that helps track and manage hard-copy document output costs for Canon branded and non-Canon branded devices. Administrators can download device workload statistics and generate usage reports by individual, group, device, or department, allowing companies to right size their devices and resources for optimal use.
Accounting Manager for MEAP resides on the imageRUNNER device and is accessed through an easy to navigate web interface. This tool gives you the ability to run customized reports and export them automatically by day, week, and month. Reports can also be run on demand.
Features of Accounting Manager:
| • | Integrates tightly with imageRUNNER devices, and can also be used with non-Canon devices via the Virtual Cash Controller (VCC). | |
| • | Track copy, scan, send & fax jobs. | |
| • | Track by paper type, single and double-sided output or N-Up output. | |
| • | Track by device. | |
| • | Track by individual, group or department. | |
| • | Track by black-and-white or color copy/print jobs. | |
| • | Multi-tiered billing codes for charge back purposes. | |
| • | Analyze department/device workload. | |
| • | Output restriction (Usage Limits). | |
| • | Report Exportation. | |
| • | MEAP application for inputting Billing Codes from the device control panel. |
